Development and validation of multitemporal image analysis methodologies for multirisk monitoring of critical structures and infrastructures - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In the framework of the monitoring of structures and infrastructures from environmental disasters, the COSMO-SkyMed constellation has a huge potential, thanks to up to metric spatial resolution, short revisit time, and the day/night all-weather acquisition capability ensured by SAR. This paper focuses on the scientific results of the project "Development and validation of multitemporal image analysis methodologies for multirisk monitoring of critical structures and infrastructures," funded by the Italian Space Agency. Several change-detection, data-fusion, and feature-extraction techniques, which were developed and experimentally validated in the project for COSMO-SkyMed imagery and for their integration with other data sources (including very high resolution optical data), are described and examples of processing results are discussed.
0005506.pdf (864.12 Ko) Télécharger le fichier
hal-00729089 , version 1 (07-09-2012)
  • HAL Id : hal-00729089 , version 1
Sebastiano Serpico, Lorenzo Bruzzone, Giovanni Corsini, William J. Emery, Paolo Gamba, et al.. Development and validation of multitemporal image analysis methodologies for multirisk monitoring of critical structures and infrastructures. IEEE IGARSS - International Geoscience and Remote Sensing Symposium, Jul 2012, Munich, Germany. ⟨hal-00729089⟩
387 Consultations
345 Téléchargements
