VisArtico: a visualization tool for articulatory data - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper, we present VisArtico, a visualization tool for articulatory data acquired using the AG500 3D electromagnetic articulograph (EMA). This software allows displaying the positions of the EMA coils that are simultaneously animated with playback of the acoustic speech signal. It is also possible to display contours for the tongue and lips. The software helps to find the midsagittal plane of the speaker and offers data-based palate shape discovery. In addition, VisArtico allows labeling the articulatory data into phonetic segments. Our main goal is to provide an efficient, easy-to-use tool to visualize articulatory data for researchers working in the field of speech production.
VisArtico.pdf (457.13 Ko) Télécharger le fichier
VisArtico_poster.pdf (1019.42 Ko) Télécharger le fichier
Format : Autre
hal-00730733 , version 1 (11-09-2012)
  • HAL Id : hal-00730733 , version 1
Slim Ouni, Loïc Mangeonjean, Ingmar Steiner. VisArtico: a visualization tool for articulatory data. 13th Annual Conference of the International Speech Communication Association - InterSpeech 2012, Sep 2012, Portland, OR, United States. ⟨hal-00730733⟩
519 Consultations
609 Téléchargements
