Adaptive Deployment Scheme for Mobile Relays in Substitution Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International Journal of Distributed Sensor Networks Année : 2012
Karen Miranda
Enrico Natalizio
We present how the mobility of routers impacts the performance of a wireless substitution network. To that end, we simulate a scenario where a wireless router moves between three static nodes, a source and two destinations of UDP traffic. Specifically, our goal is to deploy or redeploy the mobile relays so that application-level requirements, such as data delivery or latency, are met. Our proposal for a mobile relay achieves these goals by using an adaptive approach to self-adjust their position based on local information. We obtain results on the performance of end-to-end delay, jitter, loss percentage, and throughput under such mobility pattern for the mobile relay. We show how the proposed solution is able to adapt to topology changes and to the evolution of the network characteristics through the usage of limited neighborhood knowledge.
Miranda_2012.pdf (1.34 Mo) Télécharger le fichier
hal-00731821 , version 1 (11-12-2013)
Karen Miranda, Enrico Natalizio, Tahiry Razafindralambo. Adaptive Deployment Scheme for Mobile Relays in Substitution Networks. International Journal of Distributed Sensor Networks, 2012, ⟨10.1155/2012/128904⟩. ⟨hal-00731821⟩
Collections
INRIA INRIA2
124 Consultations
172 Téléchargements
