Interaction Selection Ambiguities in Multi-agent Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
To ensure multi-agent based simulation models reproducibility, particular attention must be payed on its possible implementation ambiguities. This concerns every aspect of simulation's architecture, including how the agent selects the actions it performs, and on which agents it is performed. On this point, classical agent-centered design methodologies leave room to implicit design choices. We show in this paper how an interaction-centered design methodology provides guidelines to elicit these choices, and to remove possible implementation ambiguities underlying agent design. To illustrate this issue, we study which ambiguities underly even simple models and how our interaction-based methodology makes them appear.
IAT08_NEW.PDF (93.66 Ko) Télécharger le fichier
hal-00731953 , version 1 (29-10-2013)
Yoann Kubera, Philippe Mathieu, Sébastien Picault. Interaction Selection Ambiguities in Multi-agent Systems. IEEE/WIC/ACM International Conference on Intelligent Agent Technology (IAT'08), Dec 2008, Sydney, France. pp.75-78, ⟨10.1109/WIIAT.2008.260⟩. ⟨hal-00731953⟩
106 Consultations
204 Téléchargements
