A diff-Based Merging Operator - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
Merging operators aim at defining the beliefs (resp. the goal) of a group of agents from a profile of bases, gathering the beliefs (resp. the goals) of each member of the group. In the propositional setting, a well-studied family of merging operators are distance-based ones: the models of the merged base are the closest interpretations to the given profile. Closeness is, in this context, measured as a number resulting from the aggregation of the distances to each base of the profile. In this work we define a new kind of propositional merging operators, close to such distance-based merging operators, but relying on a set-theoretic definition of closeness, already at work in several revision/update operators from the literature. We study a specific merging operator of this family, obtained by considering set-product as the aggregation function.
Fichier non déposé
hal-00732039 , version 1 (13-09-2012)
  • HAL Id : hal-00732039 , version 1
Patricia Everaere, Sébastien Konieczny, Pierre Marquis. A diff-Based Merging Operator. Proceedings of the 12th International Workshop on Non-Monotonic Reasoning (NMR'08), Sep 2008, Sidney, Australia. pp.19-25. ⟨hal-00732039⟩
226 Consultations
0 Téléchargements
