Modeling and Simulation of Mixture Flows : Application to Powder-Snow Avalanches - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Computers and Fluids Année : 2015
We are concerned with the numerical simulation of certain multi-fluids flows, which in particular arise in the modeling of powder-snow avalanches. The behavior of the mixture is described through a single mass density and a velocity field, with an unusual constraint that relates the divergence of the velocity to derivatives of the density. We discuss a derivation of the model from a Eulerian-Lagrangian description of the mixture. We propose a numerical scheme based on a hybrid Finite Volume/Finite Element method. This approach is validated by comparison to analytical solutions, numerical solutions and experimental data. The scheme works on unstructured meshes and it can be advantageously coupled to mesh refnements strategies in order to follow fronts of high density variation. We explore numerically the role of the leading coeffcients that characterize the flow: the Froude, the Reynolds and the Schmidt numbers.
Mixtures_CAF_2712.pdf (9.44 Mo) Télécharger le fichier
hal-00732112 , version 1 (14-09-2012)
hal-00732112 , version 2 (23-10-2014)
  • HAL Id : hal-00732112 , version 2
Caterina Calgaro, Emmanuel Creusé, Thierry Goudon. Modeling and Simulation of Mixture Flows : Application to Powder-Snow Avalanches. Computers and Fluids, 2015, 107, pp.100-122. ⟨hal-00732112v2⟩
783 Consultations
247 Téléchargements
