A Vectorial Solver for Free-form Vector Gradient - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue ACM Transactions on Graphics Année : 2012
The creation of free-form vector drawings as been greatly improved in recent years with techniques based on harmonic or bi-harmonic interpolation. Such methods offer the best trade-off between spar- sity (keeping the number of control points small) and expressivity (achieving complex shapes and gradients). Unfortunately, the lack of a robust and versatile method to compute such images still lim- its their use in real-world applications. In this paper, we introduce a vectorial solver for the computation of free-form vector gradi- ents. Based on Finite Element Methods (FEM), its key feature is to output a low-level vector representation suitable for very fast GPU accelerated rasterization and close-form evaluation. This interme- diate representation is hidden from the user: it is dynamically up- dated using FEM during drawing when control points are edited. Since it is output-insensitive, our approach enables novel possibili- ties for (bi)-harmonic vector drawings such as instancing, layering, deformation, texture and environment mapping. Finally, in this pa- per we also generalize and extend the set of drawing possibilities. In particular, we show how to locally control vector gradients.
vs4vg_2012.pdf (21 Mo) Télécharger le fichier
vs4vg_2012.avi (65.88 Mo) Télécharger le fichier
Format : Figure, Image
Format : Vidéo
hal-00732992 , version 1 (17-09-2012)
hal-00732992 , version 2 (17-09-2012)
  • HAL Id : hal-00732992 , version 2
Simon Boyé, Pascal Barla, Gael Guennebaud. A Vectorial Solver for Free-form Vector Gradient. ACM Transactions on Graphics, 2012, Proceedings of Siggraph Asia 2012, p. ⟨hal-00732992v2⟩
3479 Consultations
43097 Téléchargements
