Satisfying Requirements for Pervasive Service Compositions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pervasive environments are characterised by highly heterogeneous services and mobile devices with dynamic availability. Approaches such as that proposed by the Connect project provide means to enable such systems to be discovered and composed, through mediation where necessary. As services appear and disappear, the set of feasible compositions changes. In such a pervasive environment, a designer encounters two related challenges: what goals it is reasonable to pursue in the current context and how to use the services presently available to achieve his goals. This paper proposes an approach to design service compositions, facilitating an interactive process to find the trade-off between the possible and the desirable. Following our approach, the system finds at runtime, where possible, compositions related to the developer's requirements. This process can realise the intent the developer specifies at design time, taking into account the services available at runtime, without a prohibitive level of pre-specification, inappropriate for such dynamic environments.
reqAtRuntime.pdf (1005.53 Ko) Télécharger le fichier
hal-00733346 , version 1 (14-10-2012)
  • HAL Id : hal-00733346 , version 1
Luca Cavallaro, Pete Sawyer, Daniel Sykes, Nelly Bencomo, Valérie Issarny. Satisfying Requirements for Pervasive Service Compositions. 7th International Workshop on Models@run.time (MRT 2012), Oct 2012, Innsbruck, Austria. ⟨hal-00733346⟩
161 Consultations
268 Téléchargements
