An Interval Extension Based on Occurrence Grouping - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Computing Année : 2012
In interval arithmetics, special care has been brought to the definition of interval extension functions that compute narrow interval images. In particular, when a function f is monotonic w.r.t. a variable in a given domain, it is well-known that the monotonicity-based interval extension of f computes a sharper image than the natural interval extension does. This paper presents a so-called "occurrence grouping" interval extension [ f ]og of a function f . When f is not monotonic w.r.t. a variable x in a given domain, we try to transform f into a new function f og that is monotonic w.r.t. two subsets xa and xb of the occurrences of x: f og is increasing w.r.t. xa and decreasing w.r.t. xb . [ f ]og is the interval extension by monotonicity of f og and produces a sharper interval image than the natural extension does. For finding a good occurrence grouping, we propose a linear program and an algorithm that minimize a Taylor-based over-estimate of the image diameter of [ f ]og . Experiments showthe benefits of this new interval extension for solving systems of non linear equations
og_computing_2011_4_.pdf (128.89 Ko) Télécharger le fichier
hal-00733855 , version 1 (19-09-2012)
  • HAL Id : hal-00733855 , version 1
Ignacio Araya, Bertrand Neveu, Gilles Trombettoni. An Interval Extension Based on Occurrence Grouping. Computing, 2012, 94 (2), pp.173-188. ⟨hal-00733855⟩
405 Consultations
294 Téléchargements
