Improved Low Cost GPS Localization By Using Communicative Vehicles - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper, a new collaborative localization method is proposed. On the assumption that the distance between two communicative vehicles can be calculated with a good precision, cooperative vehicle are considered as additional satellites into the user position calculation by using iterative methods. In order to limit divergence, some filtering process is proposed: Interacting Multiple Model (IMM) is used to guarantee a greater robustness in the user position estimation.
P0565.pdf (1.7 Mo) Télécharger le fichier
hal-00735332 , version 1 (25-09-2012)
  • HAL Id : hal-00735332 , version 1
Evangeline Pollard, Denis Gingras. Improved Low Cost GPS Localization By Using Communicative Vehicles. 12th International Conference on Control, Automation, Robotics and Vision, ICARCV, Dec 2012, Guangzhou, China. ⟨hal-00735332⟩
Collections
INRIA INRIA2
121 Consultations
356 Téléchargements
