PEER D2.1 Draft report on the provision of usage data and manuscript deposit procedures for publishers and repository managers - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport Technique) Année : 2009
The report on the provision of usage data and manuscript deposit procedures for publishers and repository managers sets out to establish a workflow for depositing stage-2 outputs in and harvesting logfiles from repositories to enable the research, conducted in work packages 4, 5, 6 & 7. It sets out an overall framework for including repositories, whereby a critical mass of content is made available in designated repositories to provide access to users.
PEER-D2.1.pdf (519 Ko) Télécharger le fichier
hal-00735669 , version 1 (26-09-2012)
  • HAL Id : hal-00735669 , version 1
Foudil Bretel, Christoph Bruch, Natasa Bulatovic, Wolfram Horstmann, Rianne Koning, et al.. PEER D2.1 Draft report on the provision of usage data and manuscript deposit procedures for publishers and repository managers. [Technical Report] Commission Européenne. 2009, pp.49. ⟨hal-00735669⟩
243 Consultations
640 Téléchargements
