Analysis of a large number of Markov chains competing for transitions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International Journal of Systems Science Année : 2014
We consider the behavior of a stochastic system composed of several identically distributed, but non independent, discrete-time absorbing Markov chains competing at each instant for a transition. The competition consists in determining at each instant, using a given probability distribution, the only Markov chain allowed to make a transition. We analyze the first time at which one of the Markov chains reaches its absorbing state. When the number of Markov chains goes to infinity, we analyze the asymptotic behavior of the system for an arbitrary probability mass function governing the competition. We give conditions for the existence of the asymptotic distribution and we show how these results apply to cluster-based distributed systems when the competition between the Markov chains is handled by using a geometric distribution.
article.pdf (277.95 Ko) Télécharger le fichier
hal-00736916 , version 1 (30-09-2012)
Emmanuelle Anceaume, François Castella, Bruno Sericola. Analysis of a large number of Markov chains competing for transitions. International Journal of Systems Science, 2014, 45 (3), pp.232--240. ⟨10.1080/00207721.2012.704090⟩. ⟨hal-00736916⟩
542 Consultations
407 Téléchargements
