Local stability and robustness of sparse dictionary learning in the presence of noise - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2012
A popular approach within the signal processing and machine learning communities consists in modelling signals as sparse linear combinations of atoms selected from a learned dictionary. While this paradigm has led to numerous empirical successes in various fields ranging from image to audio processing, there have only been a few theoretical arguments supporting these evidences. In particular, sparse coding, or sparse dictionary learning, relies on a non-convex procedure whose local minima have not been fully analyzed yet. In this paper, we consider a probabilistic model of sparse signals, and show that, with high probability, sparse coding admits a local minimum around the reference dictionary generating the signals. Our study takes into account the case of over-complete dictionaries and noisy signals, thus extending previous work limited to noiseless settings and/or under-complete dictionaries. The analysis we conduct is non-asymptotic and makes it possible to understand how the key quantities of the problem, such as the coherence or the level of noise, can scale with respect to the dimension of the signals, the number of atoms, the sparsity and the number of observations.
localDL_HAL.pdf (439.72 Ko) Télécharger le fichier
hal-00737152 , version 1 (01-10-2012)
Rodolphe Jenatton, Rémi Gribonval, Francis Bach. Local stability and robustness of sparse dictionary learning in the presence of noise. [Research Report] 2012, pp.41. ⟨hal-00737152⟩
931 Consultations
734 Téléchargements
