Computationally Efficient MR-FDPF and MR-FDTLM Methods for Multifrequency Simulations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Antennas and Propagation Année : 2012
We propose a modification of the multi-resolution frequency domain ParFlow (MR-FDPF) method that allows simulating radio propagation channels in a frequency range. The performance of the proposed MR-FDPF implementation has been analyzed based on different realistic propagation scenarios. We also analyze the possibility of applying the multi-resolution frequency domain approach to the well-known transmission-line matrix method. The proposed multi-resolution frequency domain transmission-line matrix method provides a computationally efficient way of modeling radio wave propagation in threedimensional space at multiple frequencies.
TAP_Umansky.pdf (2.83 Mo) Télécharger le fichier
hal-00737356 , version 1 (19-12-2013)
Dmitry Umansky, Jean-Marie Gorce, Meiling Luo, Guillaume de La Roche, Guillaume Villemaud. Computationally Efficient MR-FDPF and MR-FDTLM Methods for Multifrequency Simulations. IEEE Transactions on Antennas and Propagation, 2012, 61 (3), pp.1309-1320. ⟨10.1109/TAP.2012.2227920⟩. ⟨hal-00737356⟩
236 Consultations
181 Téléchargements
