Perceptron Learning of SAT - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Boolean satisfiability (SAT) as a canonical NP-complete decision problem is one of the most important problems in computer science. In practice, real-world SAT sentences are drawn from a distribution that may result in efficient algorithms for their solution. Such SAT instances are likely to have shared characteristics and substructures. This work approaches the exploration of a family of SAT solvers as a learning problem. In particular, we relate polynomial time solvability of a SAT subset to a notion of margin between sentences mapped by a feature function into a Hilbert space. Provided this mapping is based on polynomial time computable statistics of a sentence, we show that the existence of a margin between these data points implies the existence of a polynomial time solver for that SAT subset based on the Davis-Putnam-Logemann-Loveland algorithm. Furthermore, we show that a simple perceptron-style learning rule will find an optimal SAT solver with a bounded number of training updates. We derive a linear time computable set of features and show analytically that margins exist for important polynomial special cases of SAT. Empirical results show an order of magnitude improvement over a state-of-the-art SAT solver on a hardware verification task.
SATlearning.pdf (305.32 Ko) Télécharger le fichier
hal-00738219 , version 1 (04-10-2012)
  • HAL Id : hal-00738219 , version 1
Alex Flint, Matthew Blaschko. Perceptron Learning of SAT. Neural Information Processing Systems, Dec 2012, Lake Tahoe, United States. pp.2780-2788. ⟨hal-00738219⟩
459 Consultations
357 Téléchargements
