s'authentifier
version française rss feed
hal-00738463, version 1
Policy Improvement Methods: Between Black-Box Optimization and Episodic Reinforcement Learning
Freek Stulp (Auteur à contacter de préférence) 12, Olivier Sigaud (, http://people.isir.upmc.fr/sigaud) 3
(04/10/2012)
Résumé : Policy improvement methods seek to optimize the parameters of a policy with respect to a utility function. There are two main approaches to performing this optimization: reinforcement learning (RL) and black-box optimization (BBO). Whereas BBO algorithms are generic optimization methods that, due to there generality, may also be applied to optimizing policy parameters, RL algorithms are specifically tailored to leveraging the structure of policy improvement problems. In recent years, benchmark comparisons between RL and BBO have been made, and there has been several attempts to specify which approach works best for which types of problem classes. In this article, we make several contributions to this line of research: 1) We define four algorithmic properties that further clarify the relationship between RL and BBO: action-perturbation vs. parameter-perturbation, gradient estimation vs. rewardweighted averaging, use of only rewards vs. use of rewards and state information, actor-critic vs. direct policy search. 2) We show how the chronology of the derivation of ever more powerful algorithms displays a trend towards algorithms based on parameter-perturbation and reward-weighted averaging. A striking feature of this trend is that it has moved RL methods closer and closer to BBO. 3) We continue this trend by applying two modifications to the state-of-the-art "Policy Improvement with Path Integrals" (PI2), which yields an algorithm we denote PIBB. We show that PIBB is a BBO algorithm, and, more specifically, that it is a special case of the "Covariance Matrix Adaptation - Evolutionary Strategy" algorithm. Our empirical evaluation demonstrates that the simpler PIBB outperforms PI2 on simple evaluation tasks in terms of convergence speed and final cost. 4) Although our evaluation implies that, for these five tasks, BBO outperforms RL, we do not hold this to be a general statement, and provide an analysis of why these tasks are particularly well-suited for BBO. Thus, rather than making the case for BBO or RL, one of the main contributions of this article is rather to provide an algorithmic framework in which such cases may be made, as PIBB and PI2 use identical perturbation and parameter update methods, and differ only in being BBO and RL approaches respectively.
  • Domaine : Informatique/Apprentissage
  • Commentaire : 34 pages
  • hal-00738463, version 1
  • oai:hal.archives-ouvertes.fr:hal-00738463
  • Contributeur :
  • Soumis le : Jeudi 4 Octobre 2012, 15:53:30
  • Dernière modification le : Jeudi 4 Octobre 2012, 16:03:40
tous les articles de la base du CCSd...
