Very high resolution satellite images for parameterization of tree-scale forest process-based model - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Very high spatial resolution (VHSR) satellite images provide interesting information for parameterizing tree-scale forest process-based models, and in particular their light absorption submodels, which is at the basis of photosynthesis calculation. Such tree-scale models require a large amount of field measurements to describe the forest ecosystems, i.e. all tree positions, their sizes and shapes, their leaf areas, etc. These data are generally measured directly in the field, which can be tedious for large areas like a forest stand. In this study, we explore the possibility to parameterize such tree-scale models directly or indirectly from panchromatic and multispectral very high resolution images.
IGARSS-2012.pdf (34.92 Ko) Télécharger le fichier
hal-00741004 , version 1 (11-10-2012)
  • HAL Id : hal-00741004 , version 1
Guerric Le Maire, Yann Nouvellon, Olivier Roupsard, Mathias Christina, Fabien Charbonnier, et al.. Very high resolution satellite images for parameterization of tree-scale forest process-based model. IGARSS, Jul 2012, Munich, Germany. ⟨hal-00741004⟩
433 Consultations
435 Téléchargements
