hal-00741010, version 2
Mapping local density of young Eucalyptus plantations by individual tree detection in high spatial resolution satellite images
Jia Zhou
1, 2Christophe Proisy
1Xavier Descombes
3Guerric Le Maire 4Yann Nouvellon
4Jose-Luiz Stape 5Gaëlle Viennois 1Josiane Zerubia
2, 3Pierre Couteron
1
Forest Ecology and Management (2012)
Résumé : Local tree density may vary in young Eucalyptus plantations under the effects of environmental conditions or inadequate management, and these variations need to be mapped over large areas as they have a significant impact on the final biomass harvested. High spatial resolution optical satellite images have the potential to provide crucial information on tree density at an affordable cost for forest management. Here, we test the capacity of this promising technique to map the local density of young and small Eucalyptus trees in a large plantation in Brazil. We use three Worldview panchromatic images acquired at a 50 cm resolution on different dates corresponding to trees aged 6, 9 and 13 months and define an overall accuracy index to evaluate the quality of the detection results. The best agreement between the local densities obtained by visual detection and by marked point process modeling was found at 9 months, with only small omission and commission errors and a stable 4% underestimation of the number of trees across the density gradient. We validated the capability of the MPP approach to detect trees aged 9 months by making a comparison with local densities recorded on 112 plots of ~590 m² and ranging between 1360 and 1700 trees per hectare. We obtained a good correlation (r²=0.88) with a root mean square error of 31 trees/ha. We generalized detection by computing a consistent map over the whole plantation. Our results showed that local tree density was not uniformly distributed even in a well-controlled intensively managed Eucalyptus plantation and therefore needed to be monitored and mapped. Use of the marked point process approach is then discussed with respect to stand characteristics (canopy closure), acquisition dates and recommendations for algorithm parameterization.
- 1 : BotAnique et BioinforMatique de l'Architecture des Plantes (AMAP)
- Centre de coopération internationale en recherche agronomique pour le développement [CIRAD] : UMR51 – CNRS : UMR5120 – Institut de recherche pour le développement [IRD] – Institut national de la recherche agronomique (INRA) : UR0931 – Université Montpellier II - Sciences et techniques
- 2 : AYIN (INRIA Sophia Antipolis)
- INRIA
- 3 : ARIANA (INRIA Sophia Antipolis / Laboratoire I3S)
- INRIA – Université Nice Sophia Antipolis [UNS] – CNRS : UMR7271
- 4 : Ecologie fonctionnelle et biogéochimie des sols et des agro-écosystèmes (Eco&Sols)
- Institut national de la recherche agronomique (INRA) : UMR1222 – Institut de recherche pour le développement [IRD] : UMR210
- 5 : Department of Forestry and Environmental Resources (FER)
- North Carolina State University
- Domaine : Sciences de l'environnement/Biodiversité et Ecologie
- Mots-clés : Crown identification – Object detection – Stochastic point process – Forests – Remote sensing – Brazil
- Versions disponibles : v1 (12-10-2012) v2 (06-11-2012)
- hal-00741010, version 2
- http://hal.inria.fr/hal-00741010
- oai:hal.inria.fr:hal-00741010
- Contributeur : Jia Zhou
- Soumis le : Mardi 6 Novembre 2012, 10:52:47
- Dernière modification le : Mardi 6 Novembre 2012, 13:43:01
Documents associés
Exporter
