Evaluation of Continuous Marking Menus for Learning Cursive Pen-based Commands - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Peiyu Li
  • Fonction : Auteur
  • PersonId : 931323
Adrien Delaye
Eric Anquetil
We present here the Continuous Marking Menus, which help users learning a set of handwritten commands on a pen-based interface. The aim of this paper is to experimentally attest the interest of this new type of menu by evaluating its ability to help the learning of a set of gestures. We describe an experimental comparison on the task of learning a set of gestures with or without the help of Continuous Marking Menus, and we conclude that with the help of Continuous Marking Menus, people learn more easily the gestures.
IGSfinal.pdf (159.39 Ko) Télécharger le fichier
hal-00741295 , version 1 (12-10-2012)
  • HAL Id : hal-00741295 , version 1
Peiyu Li, Adrien Delaye, Eric Anquetil. Evaluation of Continuous Marking Menus for Learning Cursive Pen-based Commands. IGS-The 15th International Graphonomics Society Conference - 2011, 2011, Cancun, Mexico. pp.217-220. ⟨hal-00741295⟩
181 Consultations
227 Téléchargements
