A remark on Lipschitz stability for inverse problems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2012
Laurent Bourgeois
An abstract Lipschitz stability estimate is proved for a class of inverse problems. It is then applied to the inverse Robin problem for the Laplace equation and to the inverse medium problem for the Helmholtz equation.
RR-8104.pdf (481.95 Ko) Télécharger le fichier
hal-00741892 , version 1 (15-10-2012)
  • HAL Id : hal-00741892 , version 1
Laurent Bourgeois. A remark on Lipschitz stability for inverse problems. [Research Report] RR-8104, INRIA. 2012. ⟨hal-00741892⟩
208 Consultations
527 Téléchargements
