The Electromagnetic Interior Transmission Problem for Regions with Cavities - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue SIAM Journal on Mathematical Analysis Année : 2011
We consider the electromagnetic interior transmission problem in the case when the medium has cavities, i.e. regions in which the index of refraction is the same as in the host medium. We address the configuration where the electromagnetic permeability is constant while the electric permittivity is variable and may be anisotropic. In this case, using appropriate reformulation of the problem into a fourth order pde, we establish the Fredholm property for this problem and show that transmission eigenvalues exist and form a discrete set. Monotonicity properties of the first eigenvalue in terms of the permittivity and the size of the cavity are established.
article_SIAM.pdf (211.17 Ko) Télécharger le fichier
hal-00743733 , version 1 (19-10-2012)
Anne Cossonnière, Houssem Haddar. The Electromagnetic Interior Transmission Problem for Regions with Cavities. SIAM Journal on Mathematical Analysis, 2011, 43 (4), pp.1698-1715. ⟨10.1137/100813890⟩. ⟨hal-00743733⟩
3079 Consultations
468 Téléchargements
