Augmented Human Engineering: A Theoretical and Experimental Approach to Human Systems Integration - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2012
This chapter focuses on one of the main issues for augmented human engineering: integrating the biological user's needs in its methodology for designing human-artefact systems integration requirements and specifications. To take into account biological, anatomical and physiological requirements we need a validated theoretical framework. We explain how to ground augmented human engineering on the Chauvet mathematical theory of integrative physiology as a fundamental framework for human system integration and augmented human design. We propose to validate and assess augmented human domain engineering models and prototypes by experimental neurophysiology.
InTech-Augmented_human_engineering_a_theoretical_and_experimental_approach_to_human_systems_integration.pdf (762.21 Ko) Télécharger le fichier
hal-00744225 , version 1 (22-10-2012)
Didier Fass. Augmented Human Engineering: A Theoretical and Experimental Approach to Human Systems Integration. Boris Cogan. Systems Engineering - Practice and Theory, InTech Open Access Publisher, pp.257-276, 2012, Computer and Information Science - "Numerical Analysis and Scientific Computing", 978-953-51-0322-6. ⟨10.5772/2121⟩. ⟨hal-00744225⟩
255 Consultations
626 Téléchargements
