On the Impact of a Small Initial Population Size in the IPOP Active CMA-ES with Mirrored Mutations on the Noiseless BBOB Testbed - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Anne Auger
  • Fonction : Auteur
  • PersonId : 751513
  • IdHAL : anne-auger
Nikolaus Hansen
Active Covariance Matrix Adaptation and Mirrored Mutations have been independently proposed as improved variants of the well-known optimization algorithm Covariance Matrix Adaptation Evolution Strategy (CMA-ES) for numerical optimization. This paper investigates the impact of the algorithm's population size when both active covariance matrix adaptation and mirrored mutation are used in the CMA-ES. To this end, we compare the CMA-ES with standard population size $\lambda$, i.e., $\lambda = 4 + \lfloor 3\log(D) \rfloor$ with a version with half this population size where $D$ is the problem dimension.
wk05p17-brockhoff_authorVersion.pdf (1.4 Mo) Télécharger le fichier
hal-00746122 , version 1 (27-10-2012)
Dimo Brockhoff, Anne Auger, Nikolaus Hansen. On the Impact of a Small Initial Population Size in the IPOP Active CMA-ES with Mirrored Mutations on the Noiseless BBOB Testbed. GECCO Companion '12, Jul 2012, Philadelphia, PA, United States. pp.285-290, ⟨10.1145/2330784.2330825⟩. ⟨hal-00746122⟩
192 Consultations
145 Téléchargements
