Error-Driven Refinement of Multi-scale Gaussian Maps Application to 3-D Multi-scale map building, compression and merging - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
The accuracy of Grid-based maps can be enhanced by putting a Gaussian in every cell of the map. However, this solution works poorly for coarse discretizations in multi-scale maps. This paper proposes a method to overcome the problem by allowing several Gaussians per cell at coarse scales. We introduce a multi-scale approach to compute an error measure for each scale with respect to the finer one. This measure constitutes the basis of an incremental refinement algorithm where the error is used to select the cells in which the number of Gaussians should be increased. As a result, the accuracy of the map can be selectively enhanced by making efficient use of computational resources. Moreover, the error measure can also be applied to compress a map by deleting the finer scale clusters when the error in the coarse ones is low.
isrr09.pdf (1.83 Mo) Télécharger le fichier
hal-00746545 , version 1 (29-10-2012)
  • HAL Id : hal-00746545 , version 1
Manuel Yguel, Dizan Alejandro Vasquez, Olivier Aycard, Roland Y. Siegwart, Christian Laugier. Error-Driven Refinement of Multi-scale Gaussian Maps Application to 3-D Multi-scale map building, compression and merging. International Symposium on Robotics Research, Oct 2009, Lucerne, Switzerland. ⟨hal-00746545⟩
294 Consultations
133 Téléchargements
