Analysis of the finite element heterogeneous multiscale method for nonmonotone elliptic homogenization problems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Mathematics of Computation Année : 2014
An analysis of the finite element heterogeneous multiscale method for a class of quasilinear elliptic homogenization problems of nonmonotone type is proposed. We obtain optimal convergence results for dimension $d\leq 3$. Our results, which also take into account the microscale discretization, are valid for both simplicial and quadrilateral finite elements. Optimal a-priori error estimates are obtained for the $H^1$ and $L^2$ norms, error bounds similar as for linear elliptic problems are derived for the resonance error. Uniqueness of a numerical solution is proved. Moreover, the Newton method used to compute the solution is shown to converge. Numerical experiments confirm the theoretical convergence rates and illustrate the behavior of the numerical method for various nonlinear problems.
hmm_nonlin.pdf (279.69 Ko) Télécharger le fichier
hal-00746811 , version 1 (29-10-2012)
hal-00746811 , version 2 (22-02-2013)
Assyr Abdulle, Gilles Vilmart. Analysis of the finite element heterogeneous multiscale method for nonmonotone elliptic homogenization problems. Mathematics of Computation, 2014, 83 (286), pp.513-536. ⟨10.1090/S0025-5718-2013-02758-5⟩. ⟨hal-00746811v2⟩
387 Consultations
221 Téléchargements
