A Testing Framework for Discovering Vulnerabilities in 6LoWPAN Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this work, we present the process of identifying potential vulnerabilities in 6LoWPAN enabled networks through fuzzing. The 6LowPAN protocol has been designed by the IETF as an adaptation layer of IPv6 for Low power and lossy networks. The fuzzing process is build upon the Scapy packets manipulation library. It provides different mutation algorithms to be applied on 6LoWPAN protocol messages to assess its implementations security and robustness. The protocol behaviors are described using an XML format to define different testing scenarios.
wisarn2012.pdf (366.76 Ko) Télécharger le fichier
hal-00747010 , version 1 (30-10-2012)
  • HAL Id : hal-00747010 , version 1
Abdelkader Lahmadi, César Bernardini, Olivier Festor. A Testing Framework for Discovering Vulnerabilities in 6LoWPAN Networks. IEEE workshop WiSARN, in conjunction with IEEE 8th International Conference on Distributed Computing in Sensor Systems (DCOSS2012), May 2012, Hangzhou, China. ⟨hal-00747010⟩
173 Consultations
722 Téléchargements
