s'authentifier
version française rss feed
hal-00747930, version 2
On the discriminant scheme of homogeneous polynomials
Laurent Busé (, http://www-sop.inria.fr/members/Laurent.Buse/) 1, Jean-Pierre Jouanolou a2
Mathematics in Computer Science 8, 2 (2014) 175-234
Résumé : In this paper, the discriminant scheme of homogeneous polynomials is studied in two particular cases: the case of a single homogeneous polynomial and the case of a collection of n-1 homogeneous polynomials in n variables. In both situations, a normalized discriminant polynomial is defined over an arbitrary commutative ring of coefficients by means of the resultant theory. An extensive formalism for this discriminant is then developed, including many new properties and computational rules. Finally, it is shown that this discriminant polynomial is faithful to the geometry: it is a defining equation of the discriminant scheme over a general coefficient ring k, typically a domain, if 2 is not equal to 0 in k. The case where 2 is equal to 0 in k is also analyzed in detail.
  • Domaine : Mathématiques/Algèbre commutative
    Mathématiques/Géométrie algébrique
    Informatique/Calcul formel
  • Mots-clés : Elimination theory – discriminant of homogeneous polynomials – resultant of homogeneous polynomials – inertia forms.
  • Commentaire : arXiv reference : arXiv:1210.4697
  • Versions disponibles :  v1 (03-11-2012) v2 (08-07-2014)
  • hal-00747930, version 2
  • oai:hal.inria.fr:hal-00747930
  • Contributeur :
  • Soumis le : Mardi 8 Juillet 2014, 15:27:56
  • Dernière modification le : Mardi 8 Juillet 2014, 17:15:27
tous les articles de la base du CCSd...
