Genome Halving by Block Interchange - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We address the problem of finding the minimal number of block interchanges (exchange of two intervals) required to transform a duplicated linear genome into a tandem duplicated linear genome. We provide a formula for the distance as well as a polynomial time algorithm for the sorting problem.
article1_extended.pdf (374.77 Ko) Télécharger le fichier
hal-00749026 , version 1 (06-11-2012)
  • HAL Id : hal-00749026 , version 1
Antoine Thomas, Aïda Ouangraoua, Jean-Stéphane Varré. Genome Halving by Block Interchange. BIOINFORMATICS, Feb 2012, Lisboa, Portugal. pp.58-65. ⟨hal-00749026⟩
755 Consultations
235 Téléchargements
