Towards dictionary learning from images with non Gaussian noise - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We address the problem of image dictionary learning from noisy images with non Gaussian noise. This problem is difficult. As a first step, we consider the extreme sparse code given by vector quantization, i.e. each pixel is finally associated to 1 single atom. For Gaussian noise, the natural solution is K-means clustering using the sum of the squares of differences between gray levels as the dissimilarity measure between patches. For non Gaussian noises (Poisson, Gamma,...), a new measure of dissimilarity between noisy patches is necessary. We study the use of the generalized likelihood ratios (GLR) recently introduced by Deledalle et al. 2012 to compare non Gaussian noisy patches. We propose a K-medoids algorithm generalizing the usual Linde-Buzo-Gray K-means using the GLR based dissimilarity measure. We obtain a vector quantization which provides a dictionary that can be very large and redundant. We illustrate our approach by dictionaries learnt from images featuring non Gaussian noise, and present preliminary denoising results.
MLSP2012_final_web.pdf (1.88 Mo) Télécharger le fichier
hal-00749035 , version 1 (06-11-2012)
  • HAL Id : hal-00749035 , version 1
Pierre Chainais. Towards dictionary learning from images with non Gaussian noise. IEEE Int. Workshop on Machine Learning for Signal Processing, Sep 2012, Santander, Spain. ⟨hal-00749035⟩
200 Consultations
340 Téléchargements
