A Singularity-analysis Approach to characterize Epicardial Electric Potential - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Oriol Pont
Hussein Yahia
Rémi Dubois
  • Fonction : Auteur
The cardiac electrical activity conforms a complex sys- tem, for which nonlinear signal-processing is required to characterize it properly. In this context, an analysis in terms of singularity exponents is shown to provide compact and meaningful descriptors of the structure and dynam- ics. In particular, singularity components reconstruct the epicardial electric potential maps of human atria, inverse- mapped from surface potentials; such approach describe sinus-rhythm dynamics as well as atrial flutter and atrial fibrillation. We present several example cases in which the key descriptors in the form of fast-slow dynamics point at the arrhythmogenic areas in the atria.
pont.pdf (342.94 Ko) Télécharger le fichier
hal-00750003 , version 1 (12-11-2012)
  • HAL Id : hal-00750003 , version 1
Oriol Pont, Hussein Yahia, Rémi Dubois, Michel Haïssaguerre. A Singularity-analysis Approach to characterize Epicardial Electric Potential. Computing in Cardiology, Sep 2012, Krakow, Poland. ⟨hal-00750003⟩
124 Consultations
120 Téléchargements
