Extensions to Higher-Dimensions of an Unconditionally Stable ADE Scheme for the Convection-Diffusion Equation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2011
Martin Guay
  • Fonction : Auteur correspondant
  • PersonId : 934772
Connectez-vous pour contacter l'auteur
Fabrice Colin
  • Fonction : Auteur
Richard Egli
  • Fonction : Auteur
An unconditionally stable alternating direction explicit scheme (ADE) to solve the one-dimensional unsteady convection-diffusion equation was developed by J. Xie, Z. Lin and J. Zhou in [6]. Aside from being explicit and unconditionally stable, the method is straightforward to implement. In this paper we show extensions of this scheme to higher-dimensions of the convection-diffusion equation subject to Dirichlet boundary conditions. By expressing the equation with a local series expansion over a rectangular grid, a linear system of symbolic equations is obtained which is tedious to solve for manually and we addressed this challenge using symbolic computation. The solutions obtained are explicit closed-form formulas which are then used to iteratively solve the unsteady convectiondiffusion equation by traversing the discrete grid in an alternating direction fashion. Finally, extensions to higher dimensions can be easily deduced from the 2D formulas. We conclude the paper with numerical simulation results for diffusion and convection-diffusion problems compared to analytical solutions showing the performance of the method and its numerical stability.
GuayColinEgli_ADE_TechRep.pdf (363.97 Ko) Télécharger le fichier
ADE.rar (1.95 Mo) Télécharger le fichier
Format : Figure, Image
Format : Autre
hal-00750389 , version 1 (09-11-2012)
hal-00750389 , version 2 (13-06-2014)
  • HAL Id : hal-00750389 , version 2
Martin Guay, Fabrice Colin, Richard Egli. Extensions to Higher-Dimensions of an Unconditionally Stable ADE Scheme for the Convection-Diffusion Equation. [Research Report] 2011, pp.21. ⟨hal-00750389v2⟩
Collections
LARA
157 Consultations
369 Téléchargements
