Logico-Numerical Abstract Acceleration and Application to the Verification of Data-Flow Programs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Acceleration methods are commonly used for speeding up the convergence of loops in reachability analysis of counter machine models. Applying these methods to synchronous data-flow programs with Boolean and numerical variables, e.g., Lustre programs, requires the enumeration of the Boolean states in order to obtain a control flow graph (CFG) with numerical variables only. Our goal is to apply acceleration techniques to data-flow programs without resorting to this exhaustive enumeration. To this end, we present (1) logico-numerical abstract acceleration methods for CFGs with Boolean and numerical variables and (2) partitioning techniques that make logical-numerical abstract acceleration effective. Experimental results show that incorporating these methods in a verification tool based on abstract interpretation provides not only significant advantage in terms of accuracy, but also a gain in performance in comparison to standard techniques.
paper.pdf (214.09 Ko) Télécharger le fichier
hal-00750762 , version 1 (12-11-2012)
Peter Schrammel, Bertrand Jeannet. Logico-Numerical Abstract Acceleration and Application to the Verification of Data-Flow Programs. Static Analysis Symposium, Sep 2011, Venice, Italy. pp.233-248, ⟨10.1007/978-3-642-23702-7_19⟩. ⟨hal-00750762⟩
178 Consultations
220 Téléchargements
