Reconciling ''priors'' and ''priors'' without prejudice ? - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Document Associé À Des Manifestations Scientifiques Année : 2013
We discuss a long-lasting {\em qui pro quo} between regularization-based and Bayesian-based approaches to inverse problems, and review some recent results that try to reconcile both viewpoints. This sheds light on some tradeoff between computational efficiency and estimation accuracy in sparse regularization.
abstract.pdf (150.5 Ko) Télécharger le fichier
hal-00751996 , version 1 (14-11-2012)
  • HAL Id : hal-00751996 , version 1
Rémi Gribonval. Reconciling ''priors'' and ''priors'' without prejudice ?. international biomedical and astronomical signal processing (BASP) Frontiers workshop, 2013, Villars-sur-Ollon, Switzerland. ⟨hal-00751996⟩
274 Consultations
134 Téléchargements
