On the Peak-to-Average Power Ratio of Pre-Equalized Base-Field Hartley OFDM - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We show by the analytical and simulation results that pre-equalized OFDM based on base-field Hartley transform (BHT-OFDM), which is an alternative air interface for LTE-beyond or 5G, provides significantly better PAPR performance than conventional OFDM systems. We develop a tractable analytical closed-form expression of the statistical distribution of PAPR of pre-equalized BHT-OFDM based on correlated multivariate Rayleigh distributions and verify the result with comprehensive simulation studies. Comparisons show that the analytical and simulation results are consistent. Our study suggests that pre-equalized BHT-OFDM is not only favorable due to its inherent error correction capability but is also highly recommendable for its superiority in power efficiency beyond today's OFDM scheme.
our_paper_PAPR_-_1569632873.pdf (166.93 Ko) Télécharger le fichier
hal-00752027 , version 1 (14-11-2012)
  • HAL Id : hal-00752027 , version 1
Lin Luo, Chung Shue Chen, Ho Siu-Wai. On the Peak-to-Average Power Ratio of Pre-Equalized Base-Field Hartley OFDM. IEEE Global Communications Conference, IEEE, Dec 2012, Anaheim, United States. ⟨hal-00752027⟩
140 Consultations
280 Téléchargements
