A Gradient-Based Implicit Blend - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue ACM Transactions on Graphics Année : 2013
We introduce a new family of binary composition operators that solves four major problems of constructive implicit modeling: suppressing bulges when two shapes merge, avoiding unwanted blending at a distance, ensuring that the resulting shape keeps the topology of the union, and enabling sharp details to be added without being blown up. The key idea is that field functions should not only be combined based on their values, but also on their gradients.We implement this idea through a family of C1 composition operators evaluated on the GPU for efficiency, and illustrate it by applications to constructive modeling and animation.
Mots clés
TOG2012_Gourmel_et_al_preprint.pdf (3.27 Mo) Télécharger le fichier
TOG_Gradient-Based.mpg (112.08 Mo) Télécharger le fichier
Format : Figure, Image
Format : Vidéo
hal-00753246 , version 1 (18-11-2012)
Olivier Gourmel, Loic Barthe, Marie-Paule Cani, Brian Wyvill, Adrien Bernhardt, et al.. A Gradient-Based Implicit Blend. ACM Transactions on Graphics, 2013, 32 (2), pp.Article No. 12. ⟨10.1145/2451236.2451238⟩. ⟨hal-00753246⟩
2318 Consultations
1850 Téléchargements
