Structured Bayesian Orthogonal Matching Pursuit
Taking advantage of the structures inherent in many sparse decompositions constitutes a promising research axis. In this paper, we address this problem from a Bayesian point of view. We exploit a Boltzmann machine, allowing to take a large variety of structures into account, and focus on the resolution of a joint maximum a posteriori problem. The proposed algorithm, called Structured Bayesian Orthogonal Matching Pursuit (SBOMP), is a structured extension of the Bayesian Orthogonal Matching Pursuit algorithm (BOMP) introduced in our previous work. In numerical tests involving a recovery problem, SBOMP is shown to have good performance over a wide range of sparsity levels while keeping a reasonable computational complexity
