Processing Stages of Visual Stimuli and Event-Related Potentials - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Carolina Saavedra
  • Fonction : Auteur
  • PersonId : 885394
Laurent Bougrain
Event-evoked potentials (ERP) in electroencephalograms reflect various visual processing stages according to their latencies and locations. Thus, ERP components such as the N100, N170 and the N200 which appears 100, 170 and 200 ms after the onset of a visual stimulus correspond respectively to a selective attention, the processing of color, shape and rotation (e.g. processing of human faces) and a degree of attention.
Neurosciences
Saavedra-Neurocomp12.pdf (149.1 Ko) Télécharger le fichier
posterNeurocomp2012.pdf (903.56 Ko) Télécharger le fichier
Format : Autre
hal-00756795 , version 1 (23-11-2012)
  • HAL Id : hal-00756795 , version 1
Carolina Saavedra, Laurent Bougrain. Processing Stages of Visual Stimuli and Event-Related Potentials. The NeuroComp/KEOpS'12 workshop, Oct 2012, Bordeaux, France. ⟨hal-00756795⟩
364 Consultations
4547 Téléchargements
