Language Evolution, Metasyntactically - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Currently existing syntactic definitions employ many different notations (usually dialects of EBNF) with slight deviations among them, which prevent efficient automated processing. When changes in such notation are required either due to maintenance activities such as correction or evolution, or because a grammar collection is written in a different notation than the one required by the grammarware toolkit, we speak of metalanguage evolution: i.e., a special language evolution scenario when the language itself does not necessarily evolve, but the notation in which it is written, does. Notational changes need to be propagated to different levels, such as to parsers that used to work with the old notation, to grammars of those notations that served as explanation material, and finally to the existing grammarbase. The solution proposed in this paper, relies on composition of a notation specification and expressing notation changes as transformations of that specification. These transformation steps are coupled to changes in the notation grammar (i.e., grammar for grammars) and to changes in other grammars written in the original notation. This paper explains the general setup of such an infrastructure, with links to the prototypical implementation of the solution.
Fichier non déposé
hal-00756852 , version 1 (23-11-2012)
  • HAL Id : hal-00756852 , version 1
Vadim Zaytsev. Language Evolution, Metasyntactically. Pre-proceedings of the First International Workshop on Bidirectional Transformation (BX 2012), Mar 2012, Talinn, Estonia. ⟨hal-00756852⟩
Collections
INRIA INRIA2
54 Consultations
0 Téléchargements
