A time-dependent saliency model combining center and depth biases for 2D and 3D viewing conditions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Cognitive Computation Année : 2012
The role of the binocular disparity depth cue in the deployment of visual attention is examined in this paper. To address this point, we compared eye tracking data recorded while observers viewed natural images in 2D and 3D conditions. The influence of disparity on saliency, center and depth biases is first studied. Results show that visual exploration is affected by the binocular disparity. In particular, participants tend to look first at closer areas in 3D condition, and then direct their gaze to more widespread locations. Beside this behavioral analysis, we assessed the extent to which state-of-the-art models of bottom-up visual attention predict where observers looked at in both viewing conditions. To improve their ability to predict salient regions, low-level features as well as higher level foreground/background cues are examined. Results indicate that, consecutively to initial centering response, the foreground feature plays an active role in the early but also middle instants of attention deployments. Importantly, this influence is more pronounced in stereoscopic conditions. It supports the notion of a quasi-instantaneous bottom-up saliency modulated by higher figure/ground processing. Beyond depth information itself, the foreground cue might constitute an early process of "selection for action". Finally, we proposed a time-dependent computational model to predict saliency on still pictures. The proposed approach combines low-level visual features, center and depth biases. Its performance outperforms state-of-the-art models of bottom-up attention.
time-dependent_saliency_model_-_V4_final.pdf (1.22 Mo) Télécharger le fichier
Format : Figure, Image
hal-00757536 , version 1 (27-11-2012)
Josselin Gautier, Olivier Le Meur. A time-dependent saliency model combining center and depth biases for 2D and 3D viewing conditions. Cognitive Computation, 2012, 4 (2), pp.141-156. ⟨10.1007/s12559-012-9138-3⟩. ⟨hal-00757536⟩
196 Consultations
258 Téléchargements
