Type-Based Detection of XML Query-Update Independence - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Proceedings of the VLDB Endowment (PVLDB) Année : 2012
This paper presents a novel static analysis technique to detect XML query-update independence, in the presence of a schema. Rather than types, our system infers chains of types. Each chain represents a path that can be traversed on a valid document during query/update evaluation. The resulting independence analysis is precise, although it raises a challenging issue: recursive schemas may lead to infer infinitely many chains. A sound and complete approximation technique ensuring a finite analysis in any case is presented, together with an efficient implementation performing the chain based analysis in polynomial space and time.
Mots clés
cr-for-hal.pdf (365.34 Ko) Télécharger le fichier
hal-00757544 , version 1 (27-11-2012)
  • HAL Id : hal-00757544 , version 1
Nicole Bidoit, Dario Colazzo, Federico Ulliana. Type-Based Detection of XML Query-Update Independence. Proceedings of the VLDB Endowment (PVLDB), 2012. ⟨hal-00757544⟩
142 Consultations
155 Téléchargements
