Anisotropic Rectangular Metric for Polygonal Surface Remeshing - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We propose a new method for anisotropic polygonal surface remeshing. Our algorithm takes as input a surface triangle mesh. An anisotropic rectangular metric, de ned at each triangle facet of the input mesh, is derived from both a user-speci ed normal-based tolerance error and the requirement to favor rectangle-shaped polygons. Our algorithm uses a greedy optimization procedure that adds, deletes and relocates generators so as to match two criteria related to partitioning and conformity.
Fichier non déposé
hal-00758023 , version 1 (27-11-2012)
  • HAL Id : hal-00758023 , version 1
Bertrand Pellenard, Pierre Alliez, Morvan Jean-Marie. Anisotropic Rectangular Metric for Polygonal Surface Remeshing. International Meshing Roundtable, Oct 2012, San Jose, United States. pp.367--384. ⟨hal-00758023⟩
139 Consultations
0 Téléchargements
