s'authentifier
version française rss feed
hal-00758152, version 1
Control-flow analysis of function calls and returns by abstract interpretation
Jan Midtgaard () a1, Thomas Jensen () 2
Information and Computation 2012 (2012) 49-76
Résumé : Abstract interpretation techniques are used to derive a control-flow analysis for a simple higher-order functional language. The analysis approximates the interprocedural control-flow of both function calls and returns in the presence of first-class functions and tail-call optimization. The analysis is systematically derived by abstract interpretation of a stack-based abstract machine using a series of Galois connections. We prove that the analysis is equivalent to an analysis obtained by first transforming the program into continuation-passing style and then performing control flow analysis of the transfored program. We then show how the analysis induces an equivalent constraint-based formulation, thereby providing a rational reconstruction of a constraint-based CFA from abstract interpretation principles.
  • Domaine : Informatique/Logique en informatique
  • hal-00758152, version 1
  • oai:hal.inria.fr:hal-00758152
  • Contributeur :
  • Soumis le : Jeudi 29 Novembre 2012, 13:22:59
  • Dernière modification le : Jeudi 29 Novembre 2012, 14:22:03
tous les articles de la base du CCSd...
