A Semi-Automatic Method To Construct Atrial Fibre Structures : a Tool for Atrial Simulations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Fibre structure and anisotropy is a determinant issue to provide accurate simulations of the electrical activity of atrial tissue. Though, atrial fibre architecture remains unreachable to standard imagery techniques on patients. A method to construct models of the fibre architecture on patient-specific geometries is then a key for numeri- cal simulations of atrial tissues. Such a method is pro- posed. Pathological and non pathological patient specific surface models of the left atria (LA) are defined. Hence, a pathological scenario is explored : a mechanism of micro- reentry in the left superior pulmonary vein (LSPV) and its interaction with the sinus rhythm (SR).
article-CINC-v4.pdf (2.66 Mo) Télécharger le fichier
hal-00759191 , version 1 (30-11-2012)
hal-00759191 , version 2 (03-12-2012)
  • HAL Id : hal-00759191 , version 2
Simon Labarthe, Yves Coudière, Jacques Henry, Hubert Cochet. A Semi-Automatic Method To Construct Atrial Fibre Structures : a Tool for Atrial Simulations. CinC 2012 - Computing in Cardiology, Sep 2012, Krakow, Poland. pp.881-884. ⟨hal-00759191v2⟩
244 Consultations
198 Téléchargements
