From Body Surface Potential to Activation Maps on the Atria: a Machine Learning Technique
The treatment of atrial fibrillation has greatly changed in the past decade. Ablation therapy, in particular pul- monary vein ablation, has quickly evolved. However, the sites of the trigger remain very difficult to localize. In this study we propose a machine-learning method able to non-invasively estimate a single site trigger. The machine learning technique is based on a kernel ridge regression al- gorithm. In this study the method is tested on a simulated data. We use the monodomain model in order to simulate the electrical activation in the atria. The ECGs are com- puted on the body surface by solving the Laplace equation in the torso.
Modélisation et simulation
