Peer-assisted VoD Systems: an Efficient Modeling Framework - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2012
We analyze a peer-assisted Video-on-Demand system in which users contribute their upload bandwidth to the redistribution of a video that they are downloading or that they have cached locally. Our target is to characterize the additional bandwidth that servers must supply to immediately satisfy all requests to watch a given video. We develop an approximate fluid model to compute the required server bandwidth in the sequential delivery case, as well as in controlled Bit-Torrent like swarms. Our approach is able to capture several stochastic effects related to peer churn, upload bandwidth heterogeneity, non-stationary traffic conditions, which have not been documented or analyzed before. At last, we provide important hints for the design of efficient peer-assisted VoD systems under server capacity constraints.
RR-8184.pdf (535.8 Ko) Télécharger le fichier
hal-00759377 , version 1 (17-12-2012)
  • HAL Id : hal-00759377 , version 1
Delia Ciullo, Valentina Martina, Michele Garetto, Emilio Leonardi, Giovanni Luca Torrisi. Peer-assisted VoD Systems: an Efficient Modeling Framework. [Research Report] RR-8184, INRIA. 2012. ⟨hal-00759377⟩
184 Consultations
197 Téléchargements
