A New Preconditionner Based on F.I.T Applied To Solve F.E.M Problem - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper deals with a preconditionner based on Finite Integration Technique (FIT) for solving Finite Element Method (FEM) problem. The geometry are twice meshed, one regular coarse used by FIT and a second irregular fine for FEM. The solution of the problem FIT is applied to preconditioned the FEM problem.
Fichier non déposé
hal-00759484 , version 1 (30-11-2012)
  • HAL Id : hal-00759484 , version 1
Abdellatif Tinzefte, Yvonnick Le Menach, Frédéric Guyomarch. A New Preconditionner Based on F.I.T Applied To Solve F.E.M Problem. CEFC - 2012, Nov 2012, Iota, Japan. ⟨hal-00759484⟩
129 Consultations
0 Téléchargements
