Real-time visual perception : detection and localisation of static and moving objects from a moving stereo rig - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We present a novel method for scene reconstruction and moving object detection and tracking, using extensive point tracking (typically more than 4000 points per frame) over time. Current neighbourhood is reconstructed in the form of a 3D point cloud, which allows for extra features (ground detection, path planning, obstacle detection). Reconstruction framework takes moving objects into account, and tracking over time allows for trajectory and speed estimation.
ITSC2012_HAL.pdf (1.27 Mo) Télécharger le fichier
hal-00759944 , version 1 (03-12-2012)
Benjamin Lefaudeux, Fawzi Nashashibi. Real-time visual perception : detection and localisation of static and moving objects from a moving stereo rig. ITSC 2012 - 15th International IEEE Conference on Intelligent Transportation Systems, Sep 2012, Anchorage, United States. pp.522 - 527, ⟨10.1109/ITSC.2012.6338872⟩. ⟨hal-00759944⟩
209 Consultations
329 Téléchargements
