Stability Analysis for Sampled-Data Systems with Input Delay - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Advanced Science Letters Année : 2012
This article proposes a novel approach to assess the stability of linear systems with delayed and sampled-data inputs. It proposes an extension of existing results on the stability of sampled-data systems to the case where a delay is introduced in the control loop. The method is based on a continuous-time modelling of the systems together with the discrete-time Lyapunov theorem, which provides easy tractable sufficient conditions for asymptotic stability. Those conditions cope the problem of stability under asynchronous samplings and time-varying delays. The period and delay-dependent conditions are expressed using computable linear matrix inequalities. Several examples show the efficiency of the stability criteria.
Fichier non déposé
hal-00760259 , version 1 (03-12-2012)
Alexandre Seuret, Wenjuan Jiang. Stability Analysis for Sampled-Data Systems with Input Delay. Advanced Science Letters, 2012, 11 (1), pp.456-461. ⟨10.1166/asl.2012.2944⟩. ⟨hal-00760259⟩
269 Consultations
0 Téléchargements
