Size Optimization of Sextic Polynomials in the Number Field Sieve - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2012
The general number field sieve (GNFS) is the most efficient algorithm known for factoring large integers. It consists of several stages, the first one being polynomial selection. The quality of the chosen polynomials in polynomial selection can be modelled in terms of size and root properties. In this paper, we describe some methods to optimize the size properties of sextic polynomials.
sopt.pdf (178.22 Ko) Télécharger le fichier
hal-00760331 , version 1 (03-12-2012)
  • HAL Id : hal-00760331 , version 1
Shi Bai, Paul Zimmermann. Size Optimization of Sextic Polynomials in the Number Field Sieve. 2012. ⟨hal-00760331⟩
205 Consultations
100 Téléchargements
