hal-00760688, version 1
Differential privacy for relational algebra: improving the sensitivity bounds via constraint systems
Catuscia Palamidessi
a, 1, 2Marco Stronati
1, 2
QAPL - Tenth Workshop on Quantitative Aspects of Programming Languages 85 (2012) 92-105
Résumé : Differential privacy is a modern approach in privacy-preserving data analysis to control the amount of information that can be inferred about an individual by querying a database. The most common techniques are based on the introduction of probabilistic noise, often defined as a Laplacian parametric on the sensitivity of the query. In order to maximize the utility of the query, it is crucial to estimate the sensitivity as precisely as possible. In this paper we consider relational algebra, the classical language for queries in relational databases, and we propose a method for computing a bound on the sensitivity of queries in an intuitive and compositional way. We use constraint-based techniques to accumulate the information on the possible values for attributes provided by the various components of the query, thus making it possible to compute tight bounds on the sensitivity.
- a – INRIA
- 1 : Laboratoire d'informatique de l'école polytechnique (LIX)
- CNRS : UMR7161 – Polytechnique - X
- 2 : COMETE (INRIA Saclay - Ile de France)
- INRIA – Polytechnique - X – CNRS : UMR7161
- Domaine : Informatique/Autre
- hal-00760688, version 1
- http://hal.inria.fr/hal-00760688
- oai:hal.inria.fr:hal-00760688
- Contributeur : Marco Stronati
- Soumis le : Mercredi 5 Décembre 2012, 11:22:15
- Dernière modification le : Mercredi 5 Décembre 2012, 11:24:48
Documents associés
Exporter
